Procharger regulator >
Old 02-29-2008, 02:04 PM
I am using the Aeromotive black pump with a 3/8" feed line to the regulator, and a 1/2" return line to the tank. We also tried a bunch of differnt disks with no luck.
baja27 is offline
Old 02-29-2008, 02:53 PM
Line size should be the other way around....Also are you getting full boost signal to the regulator? I amm assuming you have a dedicated line to the FMU....If not do this first and check your boost signal is clear. Are you running a boost guage? how do your plugs looks? If all is good then you have a problem with the FMU sticking or a fuel pump going south. Is this a new install? or is it one on a boat you bought? Who originally set it up? has it ever worked properly?
The fmu procharger uses is junk....they stick and are very unreliable
Bryan
Bryan Rose is offline
Old 02-29-2008, 03:30 PM
ZXXX Donzi's Avatar
I bet I got a spare regulator laying around. I dunno if that will solve your problems but might be worth a try. Mine worked. It did stick a little like Bryan said. That was usually to the rich side when I throttled back. Overall my transom stayed pretty clean.
ZXXX Donzi is offline
Old 03-03-2008, 11:06 AM
My aeromotive pump got weak and wouldn't achieve 65#. A new pump jumped up to 70# at the same setting.
kennyo is offline
Old 03-03-2008, 04:33 PM
Originally Posted by TylerCrockett
I keep the 2027 Regulators in stock we still use a SX or aeromotive reg in front of the Bell reg. The Bell reg is 245.00
Ordered mine today. Thanks, Tyler!
Griswald is offline
johnnyboatman
2
03-06-2006 05:48 AM
cooltoys61
1
04-09-2004 11:09 AM
puder
8
08-11-2003 01:37 PM
liquid asset
11
03-17-2003 09:50 AM
blown formula
07-19-2002 02:06 PM
Quick Reply: Procharger regulator
