Procharger regulator
Does anyone make a regulator that replaces the one procharger supplies.
What system do you have on what engine with what regulator? Usually a Aeromotive Boost referenced regulator. Aeromotive makes the only ones I have ever used. Different part number between EFI and Carb though i beleive.
I run this set up myself...crude but works extremely well, Got the info from Articfriends too.
http://www.cartech.net/fmu2020.htm
Bryan
Michigan Mad Man
Racer
Bell technology regulator......uses a needle valve to do fine tuning . Car Tech is who you are speaking of.
Bryan
Bryan
I keep the 2027 Regulators in stock we still use a SX or aeromotive reg in front of the Bell reg. The Bell reg is 245.00
It is a 502mpli m1 set up. I can not get it to reach 65lbs in boost. Even with 40lbs set at idle which is rich.
I am assuming that you are running 5 lbs of boost.
That being said, if you are going to do it long term the solution that Bryan and Tyler are talking about is better.
Bryan
