how can I loose the 496 sea water pump?
R&r Products 496 Impellor Kit
We Sell These Kits To All Of Out Customers At Redline Speed & Marine In Lake Havasu City, Az. They Work Great. Its More Affective Than Just Resurfacing The Housing. Most Housings Are So Bad You Cant Surface Anymore Off Of It. I Recommend These Kits To All Of Our 496 Customers, They Work Great.
496 Water Pump Kit
Contact Russ at R&R Products fro further details and pictures for this product. 928-453-6411.
I used that kit from R&R last summer, worked real smooth. Just follow directions. There should be an old thread explaining. I took info down to local merc tech after I did to let them know about it. The housing was made out of brass, which is very soft, right? Brass sure has not gotten any cheaper in last yr.
I am sure they would do it but the process is very simple, if you can get the pump out of the boat by yourself you can certainly install this kit.
I installed the R&R kit a year ago and it's worked well. I'll be interested to see the difference in wear compared to the brass, next time I replace the impeller.
BillR
11
07-29-2022 06:31 AM
