Gimbal Bearing - new design? Drive experts chime in plz.
OSO Moderator
I have heard there are 2 ways to install the gimbal bearing.
1st is the Merc way. Merc puts them in w/ notches towards inside of boat and the dot is visible. To remove the bearing you need a slide hammer to pull it from the bore.
OR
This way:
Take your old bearing apart by removing the bearing from the carrier by finding the install slots, rotating the bearing and popping it out of the carrier. Then install with slots facing out so you change bearing in future.
Here is a schematic of the bearing and the carrier. If you can see the "dot" like in pic A you can not remove the bearing from the carrier. If it looks like pic. B, you can remove the bearing from the carrier.
Now,
I was told they have redesigned the gimbal bearing for Bravo X and above. The new design has an offset and allows the bearing to sit 1/8" further in (away f/ drive) to allow for the larger u-joint shaft. Thus if you install bearing the other way (so you can remove it) that it will eventually cause damage. Was also told Merc put out a bulletin on this.
Is this all true????
OR
This way:
Now,
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
I replaced my gimbal bearings when I winterized my boat last fall and installed them the aftermarket way so you can see the 2 notches,and replace the centers without a slide hammer.
I have Bravo drives and was told it wont hurt anything,seems to line up ok.
Merc has always suggested to replace the complete bearing. For years before the XR's many people would cheat and just replace the bearing and leave the race. Merc began installing the original so that you had to change the complete bearing. If you have a pre XR you can cheat. If you have an XR or newer you better not. Pay attention to the offset in the bearing. Old style is centered new is not.
Masher touches my
At one time they had a two different sized gimbal bearings. One was for the bigger u-joint assembly on the X series drives. Now all the gimbal bearings are the same size (smaller) and will fit in any application. At the same time they also made the u-joint assemble a little smaller on the new X series drives. I always put the dot on the outside, and line up the grease fitting. It never made sense to me that they didn't put the dot where the grease fitting was so you could line it up easier on installation.
