New (to me) boat / need to rebuild engine
Just checked the oil and it's atleast a quart lower then when I ran the boat for less then an hour yesterday. Did a compression test and all cylinders are between 130-138PSI EXCEPT #8 at 62PSI. I also just tried to start it and magically no water would flow through the exhaust! Any advise would be appreciated.
James
James
water can take some time on hoses to flow out...not too long though! I suppose you have a 454 or 502. compression should be more in the 150 to 180 range, mostly equal, but certainly not one at 62. this one is burning oil for sure... unless you have a valve problem but you say burning oil so... I'd get a leak down test done to make sure you know what the problem is. I had many 454 MPI rebuilt completly for 3k, bottom to top... Hope this helps but let us know!
Registered User
squrit a shot of oil into #8,and do another compression test on that cylinder.if the pressure increases,the rings most likely are the problem.if pressure stays the same,then you have other issues.hope this helps
gotime34
07-10-2005 08:20 PM
