upgrading gen 6 mechanical fuel pump >
Old 04-09-2008, 12:45 PM
If you are running Holley carbs you do not need a regulator. I have been using one for years. You do need too rebuild once every 100hrs or so, the valves start to leak, but the parts are only about $60-80. Easily supplies 700-750hp.
PPlay33 is offline
Old 04-09-2008, 11:01 PM
Originally Posted by Ran-Dom 32
$418 + you need a regulator ( 2 x)
I called their 800 no. this morning and was told $390.00, and no need for a regulator. Hhmmm......
Kidnova is offline
Old 04-10-2008, 02:09 PM
AIR TIME's Avatar
I go with the Diamond Performance kepp set up it will be cheaper. I have the same kit on mine since 96 . will no troubles yet pushing 670hp now started at 585hp back in 95.
AIR TIME is offline
Old 04-10-2008, 03:20 PM
Ran-Dom 32's Avatar
yep, that's what I'm going to purchase
Ran-Dom 32 is offline
Old 04-10-2008, 05:07 PM
Hey Bill, When I talked to CV, I spoke with a techie that when asked about psi, he said something like 8 to 10 lbs. He did recommend for a consistent 7 lbs, use a regulator. The 7 lb. figure came from my carb guy.
FYI-----For those who want to use the CV2630, I have the fitting part numbers that you may need to use this pump.
Just for you Bill, I ordered a set of Jesel Pro shaft rockers for my dyno motor.
Attached Thumbnails upgrading gen 6 mechanical fuel pump-cv-billet-fuel-pump-001.jpg
ROTAX454 is offline
Old 04-11-2008, 05:28 PM
Jeeeezuz. When I talked to CV the guy told me 7-8 lbs, and no regulator needed. Like talk'n to the phark'n IRS. Ask 10 ?? and ya get 10 answers. No matter though. Think I have the issue solved. I'll give ya a buzz and let you know. Thanks again Dave !!
Cool Richard, those rockers do ROCK However, I cheaped out and went with the sportsmen, and we had issues with the stands Maybe I should'a gone with the pro's I don't know about set up with the pro's. Ya might want to give Yoda a call and talk about that. He knows a guy somewhat close to you that I believe is quite familiar with them
Lemme know how the dyno session goes !!
Kidnova is offline
BillR
27
08-10-2008 11:31 PM
Craig B
4
06-16-2007 08:42 AM
greencard
10
02-12-2006 01:36 AM
StrikinLightnin
10
01-08-2005 12:30 AM
Kirch
3
07-08-2002 02:12 PM
Quick Reply: upgrading gen 6 mechanical fuel pump
