HP Increase Whipple >
HP Increase Whipple
HP Increase Whipple
Old 03-28-2008, 10:31 AM
Charter Member #139 /Moderator/Platinum Member
klaw's Avatar
Default HP Increase Whipple
I have a couple Carbed 500 HP that were gone through a few years ago the are at 565 hp at 5400 rpm and have 850 Demon carbs also they are 9.25 to 1 compression.
Can I add 100 HP per motor whith Whipples with not to much problem?
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 03-28-2008, 08:22 PM
Charter Member #34
Dock Holiday's Avatar
Whipples will give you 200 to 250 HP easy.
Dock Holiday is offline
Old 03-28-2008, 08:54 PM
Whipple Charged's Avatar
100? Come on man, go for it! 100 is very, very, very, very easy. Would highly recommend 200hp, which again, is very, very, very, very easy!
Dustin
Whipple Charged is offline
Old 03-28-2008, 08:59 PM
Charter Member #34
Dustin
Dustin sorry to ask but is that easy , very easy or very, very, very easy?
Thanks for all the help buddy!
Old 03-28-2008, 09:23 PM
klaw's Avatar
Dustin
What size should I use and should a?
inter cooler be involved?
Will the 850 Demon be enough carb
klaw is offline
Old 03-28-2008, 11:59 PM
A single 3.3 liter with an intercooler is a must. You will need more carb for this setup. You will have to step up to a dominator. As a note, I build all of my Whipple supercharged motors with almost as much compression as you have. I have found that spinning the blower slower to make less power makes for an engine that is not as happy. Distribution from cylinder to cylinder is not as good with a slower spinning blower and air/fuel ratio from bank to bank starts to differ. Take the free horsepower and spin it. You will not regret it, but your Bravo may. That is an awesome blower package. Give me a shout if I can help.
Eddie
Young Performance is offline
Old 03-29-2008, 10:30 AM
I agree with Eddie the engines will run better turning the blowers the only concern I have is any time I've ever made over 750hp with the stock dimple rods I've had trouble also John at AED makes a 4150 carb that flows over 900cfm I use on my blower packages and works really well I like the idle quality and mid range better then with Dominators but you can get them to work well too. Best of luck keep us posted. SIncerely Laz Mesa
www.mesabalancing.com
MESABALANCING is offline
Old 03-29-2008, 02:26 PM
Dustin
If you want to keep it under 900hp, then our Gen 2 3.3 SC is more than enough for you. Eddie is correct about your carb, too small, should go to a 1050 dominator.
If you really only wanted 100hp, then an intercooler is not necessarily required, but the value added for the IC far exceeds the risk of no intercooler, so I would plan to IC it.
A W305 would work really well, but it's far more expensive, and will just be loafing around, yet you'll have the ability to make basically whatever power level you want, it all depends on the lower end. There is zero distribution problems with the large W305. It has a built in deflector plate and a 2" plenuem chamber above IC.
Thanks,
Dustin
Old 03-29-2008, 02:30 PM
Rob
Strip Poker 388's Avatar
Why just 100?
Strip Poker 388 is offline
Old 03-29-2008, 08:43 PM
klaw's Avatar
I have a Cig Bullet built the 500hps 3 years ago has bravos have not popped a drive yet has xr vert shafts I baby it out of the hole but if I go more then 120 hp barvos get iffy. Would not mind more and just swap into the gun when I get it because it will have ssm 3s on it but for know 100 would be fine
klaw is offline
Quick Reply: HP Increase Whipple
