Trs Transom Install
reinstalling my trs transom assembley's should i put some 5200 calk on them with cork gasket or no calk ?? any help would be greatly apric. thank's.
I used a little sika flex on both sides of the gaskets. I would not use 5200!!!! Someday someone will have to take those off again and with 5200 that would not be pretty
Registered User
If the transon is smooth and level and the gimbal surface is intact, you should need nothing on the cork gasket. If not, fix the problem, don't goop up the transom. And don't over-torque. Most gaskets fail from being over-tightened.
