Gil Marine or Imco exhaust
I have a chance to get a used set of each. Is one better than the other and what would be a fair price. They come with the risers.
This will be going on a 1998 7.4l
Registered User
The merc is a different casting and reportedly more leak-prone. The Gil is vulnerable to heat damage right in the exhaust pocket- if you lose an impeller and run them, they'll crack/melt there. A visual inspection is paramount, a pressure test is easily accomplished.
Gil makes wedges that allow for tailpipe fitment if they're the long-pipe style.
Thanks guys for the input, but I'm about to show my inexperience. Chris when you says wedges, does that mean wedges that would go underneath the riser to change the angle? If thats the case, I don't think I'll have to worry as I am now using the stock exhaust which makes a sharp dowward angle and the back. I plan on installing 4" tips straight out the back.
Registered User
Remember the old carpenter's adage on those thru-hull holes...
"Measure twice, cut once"
