got a car question, oil in radiator, no water in block
99 honda accord. Oil in water, made a chocolate shake in the radiator, but no water in the block. Looks like the water blew out as the radiator is low.
Is it an obvious head gasket? Runs good, no smoke. How would I check before tearing apart since its still running good.
Thanks in advance
Thanks in advance
If its a automatic its probably the trans cooler in the radiator that leaking
Yep, check the trans oil level. Disconnect the cooler lines, plug one and apply 15 or so psi to the other, whatch rad for bubbles. If ok, could very well be a head gasket. Oil is under much higher pressure than coolant. One way transfer.
Most likely head gasket, but occasionally I have seen these crack the block between the cyl liners, check very carefully on the deck after cleaning.
I hate the winter!!
I am not an expert on Hondas, but some cars have an engine oil cooler in the radiator as well as a trans cooler. If it does have one, it sounds like that may be the problem. I have never seen a head gasket cause oil to get into the water. They can cause water to get into the oil.
Strawberry shake= tranny cooler in rad shot, chocolate shake=head gasket or head shot. All is true except if your customer puts the wrong oil in the wrong place(as in the rad) of which I have seen before.
I've seen this also. Depends on the design of the cooling system and nature of the failure, sometimes you can get a sort of siphoning effect where the cooling system will draw oil from the motor. VERY common problem with the old 2.8L Chevy they ran in the S-10 series pick-up's.
