454/420 with 496 manifolds????
A friend of mine has older 454's built to 420 specs. He currently has the stock merc center riser iron manifolds. Would going to a set of new style 496 aluminum manifolds be worth some HP over the old style iron ones?
Would the 496 exhaust bolt up to the old style 454/502 rectangular port heads? I thought there were issue with the bolt pattern. Had to redrill stock CMIs to get them to fit a new 496? Something like that?
Also, I believe you are correct about replacing the stock cast iron Merc exhaust with a better free flowing exhaust....especially if you've added a hotter cam. Your engines should respond with some kick...especially in the midrange and maybe 1-2mph on top as Griff said.
