OIL(s) Survey - Engine-Trans-Drive
454 mag, modified to 700 hp
crankcase mobil 1, 15-50 synthetic............25 hr intervals
bravo 1 merc high performance +, green....50 hr intervals
blower mobil fully synthetic 75/90..............25 hr intervals
engine taken down this winter by Twister engines after 2000 hrs.
Gary inspected, and commented re maintenece, no oil related mechanical failure, no heat problems, engine just "tired".
engine block to go .030 over (first time) new cam and valve train.
same lubricants and intervals to be used in new set-up based on history of old.
see you this season,
bruce
bruce
29' Nordic w/525 SC---Redline 20-50 synthetic
Bravo 1---Redline shock proof heavy
18' Hallet v-drive w/392 blown chry hemi----Redline 20-50 synthetic
V-drive---Redline shock proof heavy
Bonneville Saltflat race car---
540-572-632 cu in unblown injected marine big block w/500 hp variable NOS sys.---Redline 50 wt Racing synthetic.
Liberity air shifted trans---Redline synthetic ATF.
Chev 12 bolt rear end w/posi--- 90 wt hypoid gear oil (Synthetic gear oil caused loading/unloading of clutch pack at speed)
Car (98 Trans Am) holds 5 world land speed records pending class/engine size. Records vary from 244 MPH to 295 Mph.
Engines are built very similar to off shore marine engines except for cam, valves and compression. Engines pull WOT for 7 to 8 miles (7100-7400 rpm) pending salt conditions with 5 or 6 miles for shut down
jeff32
06-28-2006 08:48 AM
Wally
6
06-27-2006 08:22 AM
