Would I gain anything porting intake to match cylinder heads? >
Old 04-24-2008, 09:52 AM
The GM gasket is a PERFECT match to the heads and intake. Using this gasket as a template, you will find that no grinding in needed. This is a "cnc port-matched" intake afterall.
69-CHVL is offline
Old 04-24-2008, 10:01 AM
[QUOTE=AIR TIME;2536698]FOR 200 to 250 IT WOULD BE MONEY WELL SPENT and have a pro do it right the 1st time. I plan on having DEAN do mine and also change my cam if I have any coin left over this summer. his engines are in some expensive boats you know like OUTERLIMITS. and he has always helped people on line here.
Ditto on that BIG Daddy , real cheap HP there and Dean is the man without all the B/S .... Dean got the Gear lube & the Mercury parts and you were dead on she fired right up..Thnx again Good luck BIG JIM
Old 04-24-2008, 12:39 PM
Location: Omaha, Nebraska. Boat on the Mighty Mo! Longest river in the USA!
Do you happen to have a part number for this gasket? I guess I see that intake laying on the floor, is it for sale?
Anyway you take a picture with it on the intake?
I agree it would be worth the money. I think I would be better off doing the intake and work on the heads at the same time. I am kicking myself now
1BIGJIM is offline
Old 04-24-2008, 08:54 PM
Sorry, I dont have the intake, I lifted the pics from the internet.
Here's the part# - little spendy though:
GM PART # 12366985
69-CHVL is offline
Old 04-25-2008, 07:32 PM
Default Port Matching on a Stock Intake and Head setup
Is there anything to be gained on stock OEM Merc parts? I have 502 MPIs which will be coming apart for some upgrades and wonder if there is anything to be gained? It would seem if there were HP gains available that the intake and head castings would be adjusted over time to correct any misalignments in the ports??? Also when port matching, how far do you blend the opening? It seems that if the intake port on the head is not opened up all the way to the valve the gains would be minimal.
Thanks.
Inspector is offline
BajaRunner
2
07-15-2006 10:41 AM
fbh-velocity
0
04-21-2006 11:40 AM
BajaRunner
12
10-25-2005 11:19 PM
bouncedcheque
20
01-16-2005 04:09 PM
barron
1
01-16-2005 03:01 PM
Quick Reply: Would I gain anything porting intake to match cylinder heads?
