Mesa Racing Engines Small Block Blower motor
Hey guys here is a couple of shots and a video of a small block we just completed for a 24 Pantera we used a tight lash solid roller with a real mild ramp design and under .650 lift we made 687hp @ 5800 rpm and 703 hp at 6300 rpm on pump gas with 5 lbs of boost this thing makes over 600 ft lbs anywhere above 3000rpm and close to 690 ft lbs at peek. Torque curve was great and the bsfc numbers are all in the mid to low 40's we used a pair of 750hp's with little work in the air bleeds and have great idle quality and throttle response . Using a pair of iron angle plug dart heads with minimal porting work the blower was an 8-71 the block was a Dart piece with 350 main size and 4.155 final bore . Thought you guys would enjoy this project. We were ona tight budget and didn't use alot of polished items I feel we had some room to improve it's looks but the customer said we know we don't need chrome or polished aluminum to make a good dependable power I built two blown 383's for another 30 Motion he had which ran 146mphs in Venezuela and he was tickled with those engines. Sincerely Laz Mesa
www.mesabalancing.com
check out the video in youtube.http://youtube.com/watch?v=qWGpWHpRMH8
