Car question, Had a head gasket blow, fixed, now trying to clean oil out of radiator
Blew a headgasket on a honda accord and have milkshake oil and water in the radiator.
Fixed the headgasket, but the milkshake is in all the lines. Whats the best way to clean the system out? I took out the thermostat, was thinking about putting a water hose in and trying to spray as much out as possible, but its pretty gunky.
Any suggestions?
Any suggestions?
Flush out as much as you can. Then pour about a third of a box of dishwashing power soap into the radaitor. Run it till it gets hot maybe a short drive to make sure everything mixes well and dump it .We used to have to do this in the big diesel engines when they would bust an oil cooler. Since oil pressure is higher than the water pressure they will always dump oil into the coolant.
he's got it , dish washing detergent , like Dawn or Palmolive
it has the ability to loosen the oil from the radiator surfaces its stuck too , and makes your hands nice and soft during the process
BajaRunner
13
05-13-2008 08:54 AM
