Seawater Impellors >
Seawater Impellors
Seawater Impellors
Old 05-05-2008, 06:55 AM
Default Seawater Impellors
How often does everyone change seawater impellors...every season?.....every other season?...I change mine annually, but I have friends that say that it is not necessary to change them each season...??????
GRSFAST is offline
Old 05-05-2008, 06:59 AM
21 and 42 footers
t500hps's Avatar
I replace them every spring...housing and impeller. A buddy will pull his housing off and take the impeller out to leave un-bound for the winter then re-use it for a second year.
t500hps is offline
Old 05-05-2008, 01:25 PM
baja bailey's Avatar
I have always did it every other year with no problems.
baja bailey is offline
Old 05-05-2008, 01:31 PM
SORE MEMBER
Wobble's Avatar
I always change mine when I see the exhaust hose smoking or every other year whichever comes first
Wobble is offline
Old 05-05-2008, 02:04 PM
Thumbs up
Every spring when I do all fluids. I had one engine out last month and just checking one water pump (had been changed 7 months ago) and found a blade had broken off and another cracked. If I have one engine out for some reason, I go ahead and change both water pumps then because its easier to get to. As expensive everything else is it is cheap insurance.
team Tickfaw is offline
Old 05-05-2008, 02:14 PM
Knot 4 Me's Avatar
Every other season. My most recent one had 120 hours on it and looked like new but it is worth the piece of mind.
Knot 4 Me is online now
Old 05-05-2008, 02:16 PM
The first time I changed my Alpha impeller on my 1979 228 was in 2002. It still worked fine but the temp was starting to wander. So they can last a long time. I am sure newer ones won't last as long. Now I change my Bravo one every 2-3 years.
Pismo10 is offline
Old 05-05-2008, 03:16 PM
Thanks Guys...i Think That I Will Now Change Mine Every Other Season....instead Of Every Season...
GRSFAST is offline
Old 05-05-2008, 07:20 PM
Ginger or Mary Ann?
US1 Fountain's Avatar
I always get 2 yrs out of mine. 1 yr and still look good. 3 yrs ends up replacing one on the water. (twice now)
Just replaced them again last week for the 2 yr change. 1 missing vane, 1 was 1/2 tore.
US1 Fountain is offline
Old 05-05-2008, 08:05 PM
21 and 42 footers
t500hps's Avatar
Ever wonder where the missing vane went???? Probably hung up in the oil cooler.
t500hps is offline
Quick Reply: Seawater Impellors
