water pressure too high??
http://www.grainger.com/Grainger/items/1CKX6
Registered User
Low pressure releif. 15lbs. It didn't work the best untill i made the mods you see in the pic. It leaked water out the stem.
I dumped over board through a thru hull fittiing. I used
1" hose. I cut about 3/8 off the spring. Shorten the stem by 1/4 " and made the nylon piece to screw in the top to hold the valve in place. Put the valve back together using a sealer. Hope this helps. Like I said before this works great. 15 lbs at 3800 and about 20 lbs @WOT
Registered User
pretty coolstuff noise pollution.what kind of pressure were you seeing to make you go w/a relief valve.i changed my drive last year on my fountain.it has a multi-pick-up on the water inlet.my boat guy said all the new bravo1 come that way.since then my pressure is higher,wot about 30-35.boat guy said mercury said that is ok.i have heard diffrent stories from diffrent people.so i am wondering.
Registered User
