Prop what pitch
I got a 24ft Baja with a 454 mpi with Gil exhaust. It seems to go pretty good now with a Bravo1 24p 4blade and revs 49-5000rpm. It just barely hits about 65mph on the speedo. Is there more mph there with possibly another prop pitch or design.
you have to go to a 25 mirage 3 blade !4 blades lift the back of the boat baja likes 3 blaDES THEY LIFT THE BOW I TRY ALOT OF PROP BEEN THERE .TRY 25 MINE TRUN 4800 I HAD CUP REMOVE IT RAN 5000 AT68MPH
Is it a 24 outlaw or a 240???
I would guess a 240 from your numbers. Almost all 24 Outlaws with stock 365-415hp run a 23 Mirage plus for the fastest top end. Plaining time sucks.
A 240 is lighter and has less deadrise, so a 25 Mirage plus would be the prop for the best top speed. Cruise speed and plaining time will suffer though.
