525hp marine 496 from GM >
Old 05-13-2008, 01:45 PM
Originally Posted by HTRDLNCN
I still never got the resistance GM has for running forged pistons in their newer engines
(LS1/2/etc and 8.1s) instead going for the Hyperpathetics.
First thing everyone is forced to do when making real power in a newer LSx or 496 engine whether car or boat is take the damn thing apart and get some real pistons.
Everything I have read says, hyper pistons are used for emissions and noise reasons. They expand less than forged pistons, thus have a better seal when cold, producing less blowby at that time. Plus, much less $$.
Darrell.
DMOORE is offline
Old 05-13-2008, 01:57 PM
You are correct but we are talking high perf and heavy duty engines here , I am sure the guy buying an LS1/2/etc powered performance car or the guy buying the one ton truck would not mind paying an extra couple hundred dollars to get forged slugs.
One of the reasons the 5.0 fords gained the following they did was because the stock forged pistons made them easy to supercharge or spray without worrying about cracked pistons,, the newer supercharged Mustangs and Lightnings all had forged slugs.
Maybe I am not business minded enough but still seems like a dropped ball by GM to save a few pennies.
HTRDLNCN is offline
Old 05-13-2008, 02:20 PM
Canada Jeff's Avatar
WTF is a ' NASCAR spring ' ?? The same springs used in Jr's engines?? Just wondering.
Canada Jeff is offline
Old 05-13-2008, 02:38 PM
Rage's Avatar
Nascar Springs:
http://www.compperformancegroupstore.../merchant.mvc?
Nascar springs are high rate high stroke springs sufficient to keep the valve train in contact at 10,000 rpm on a high lift cam and that are made of high purity spring steel that will also survive an x-hour race at 10,000 rpm without suffering fatigue that would allow the valve train to seft destruct. Also about double the cost of a typical spring.
Rage is offline
Old 12-23-2009, 10:19 AM
Default Cam only?
So adding a HP3 cam only would do nothing for a stock HO except the possibility of reversion?
Baja_man is offline
Old 12-23-2009, 05:58 PM
blue thunder's Avatar
Darrell.
I run hyper piston in a blown engine with 9.5:1 static compression. The engine next to it has forged pistons. Same setup on each engine except for piston fit and ring end gaps. Producing around 700hp each by my estimation. End of season run, both engines to the pins for more time than usual, which is usually a lot anyway... 3 melted forged piston. Hyper engine is crisp and happy with no problems. This was the 5th season on the hypers, 2 seasons being roots blown. The one year we had hypers in both engines but had a failure unrelated to pistons that led to trying forged in the other engine. Forged didn't even make it one season. So why do you question GMs choice on pistons again?? If set up right hypers outperform forged. The caveat is if a setup problem occurs, the hypers crack and explode, the forged melt which is a usually a happier ending for the rotating assembly and block. The problem people have with hypers is they bolt on blowers without changing the ring end gaps. They try to do this with FI and no ability to tune the FI curve to make the engines live. It really gives hypers a bad name which to me is ill deserved. Learn how to build an engine correctly, you can run hyers all you want and make more power than with forged.
blue thunder is offline
Old 11-30-2016, 10:45 PM
Received 1,421 Likes on 793 Posts
I know old thread, did anyone ever try these out and if so any issues?
Wildman_grafix is offline
LAKESIDE RESTORATIONS
New Products and Member Discounts
5
05-03-2007 12:24 AM
288sunny
18
03-28-2007 08:38 PM
30 outlaw 2005
2
05-13-2006 08:16 PM
sonic28
2
07-31-2005 02:35 PM
klmken
05-18-2005 02:05 PM
Quick Reply: 525hp marine 496 from GM
