Calling ROOKIE
Brotherhood #1
i have merlin 2.20/1.88 cast heads. i can get cast numbers if needed. has a small burn mark between the center 2 cylinders. i only want 700+ shipping
Jeff,
After looking at the head with JimV it is a standard head that has not been cut. I can see the difference on the surface from the one that was cut. The head was fitted with 2.25" instead of standard 2.19". I have the valves that were in the head and maybe have another 4 for another head if you want to replace your existing head with 2.25".
Jason
Jason
