Prop spin?
Morning everyone, I have a question to throw out here. My 30' Sleek has a 502 w/whipple supercharger and xr drive with 1.5 ratio w/ 5 blade maximus 28 pitch. I dyno tested at 750hp and love the motor. My proplem is that as I come up to plane it sounds as if my prop breaks free and builds rpms. Once I plane out and start to gain speed it sounds as if my prop grabbs and dropps rpms and I'm able to lay into it. I don't WOT out of the hole and would like everyones advice on the cause and cure for this.
It's called prop blowout. My 30P Labbed Maximus do that as I come up on to plane. Just have to learn the best throttle to keep it at a minimum. What are the rest of your specs, you may need to change the prop depending on slip percentage, top speed, and WOT rpms. My 32P Bravo's did it, too. I think you are just overpowering the props.
Thanks guys, I figured as much. It does great at WOT, I just was wondering if I needed a cav plate or tube or if there was something else I could try incase I'm slipping a little a WOT as well. I still need to get the prop labbed, but has been the best fit for the boat so far.
