Max RPM on a 330 merc?
You actually put more of a load on the motor dragging it down to 4200 or 4400. You are probably in the secondaries at 3200 or 3400. At 5000 k your not in the secondaries till later maybe 3600. You can cruise at 75% throttle at 4000 or 4200 endlessly.
Having bigger motors is nice but they don't live near as long. we would burn the belts off and add gas. Pretty good boating.
I have a 454 started life as a 330. Have about 300 hours on it now.
Spins 4800 all day long in my jetboat. I changed the heads, cam, intake, and exhaust about 5 years ago. That really livened it up. Could probably handle 4900 or 5000 now but will need a shorter impeller. It's a workhorse and 4800 seems very safe (especially for non-forged internals), so I'll leave it like this til the motor wears out or lets go.
I think it's a good motor with the right cam, heads, and exhaust.
When it's rebuild time, you can pick up an easy 100hp with a few simple changes.
Enjoy!
Enjoy!
4800 is a good number. Most 330's that fail that I've seen is a result of a leaky exhaust like a riser gaskets. I suggest you change them every few seasons don't wait for them to begin to weep. Its cheap and easy to do.
Got a buddy running stock '96 330 bottom ends with Brodix heads, roller cams, Merlin intakes, 4150 Holley's, MSD inginition, and CMI e-tops. Runs them 5K with no problems. Probably would not want to spin them much faster for any length of time.
Prop for 4600rpm with a normal load; then you'll be at 4800 real light or 4400 real heavy.
The engine will not make more power above 4600.
Patrick
Patrick
That is exactly what I've done with mine. I tried 4 props before I found the one (Revolution 4b 21p) that put me in that sweet spot.
