Diacom evaluation
Does anyone see any reason this should be going into gaurdian mode? The sea pump pressure is a little high,but only 1 of 2 motors is going into gaurdian! They both have the same sea pump value!
4 Guardain
FF Baro Pressure 13.64 PSI
FF Battery Volts 13.41 VDC
FF Sea Pump Pressure 42.89 PSI
FF Boat Speed 74.00
FF Manifold Air Temp 118.00 øF
FF Coolant Temp 169.00 øF
FF Demand 96.70 %
FF Engine Speed 4874 RPM
FF Engine State Running
FF FPC Total 77.6 Counts
FF Frequency Count 4
FF Fuel Level 0.00 %
FF Gear Position In Gear
FF Lake Temp 430.00 øF
FF Engine Load 36.96 %
FF Main Pwr Relay Requests 33812.0
FF Manifold Air Pressure 13.05 PSI
FF Oil Level 0.00 %
FF Port Tab Pos 0.00 %
FF Available Power 99 %
FF Run Time 65.03 hrs
FF Starboard Tab Pos 0.00 %
FF TPS Percent 96.70 %
FF Trim Position 23.65 %
4 Guardain
FF Boat Speed 74.00
FF Demand 96.70 %
FF Oil Level 0.00 %
The Seapump pressure is real high, what is the pressure at idle?
What are the other stored faults?
Not sure what engines you have, maybe your hitting the rev limit (any stored overspeed faults?).
We had a problem when the computers were reprogrammed! Seems there is no correct program for 07 yet. Sea pump pressure is 28 when engine is off. The value is wrong. The only thing that was stored was a overspeed after it went into gaurdian!
