525sc - what thermostat and engine temps
I replaced the 140 thermostat with another 140 thermostat....
back flushed the oil cooler. cloudy water came out but no chunks
ran the next day to 4000 rpm. ( with the family)
port 155 deg, starbaor 160. I think I am jsut fine
just was not sure where these settle to....
I think they are ok
Ramb
I think they are ok
Ramb
I think they are ok
Ramb
I think they are ok
Ramb
scott
we could swape the gages, and/or senders to see if it is the sendors or the actual water temp that is different
but I am less worridd myself now seeing only a 5 degree difference
Ramb
Ramb
on injected motors with a typical recirc water pump, with a standard tstat ( no holes or other voodoo) the water temps should be above 160 or you are telling the injection to be over rich... not smart.
not smart on carb motors either but not essential like it is with injection. a good injected , normally aspirated motor will run for 200 years at 170 deg... where it should be anyway.
