wiped out flywheel teeth on "95" 540cu
Last fall my starter stuck out, engages into my flywheel ring gear. It ate from 1/16" deep to over 1/4" into the ring gear. I had one more outting planned and did not have time to pull the engine for repairs so I pulled the starter and with some creative dremmel and file work through the starter hole the ring was dressed enough to install a new starter and make one more weekend of it. Trust me this was almost as hard as pulling the engine,
I have the engine out now but have run into another problem.
The engine is a 1995 model 540 BULLDOG with only 212hrs.
This model from what I know was externally balanced with the fly wheel on. Hence the problem. I am almost sure they did not internally balance without the flywheel until late 96. I called Merc high performance and they had to be reminded of that fact when asking for advice. I got none! If I would'nt have known about the balanceing and followed thier instructions, I'd have thrown a complete flywheel on the engine and created a 25K granade.
The ring gear is just pressed onto the actual flywheel. I was wondering if I could cut the ring off, purchase a new ring, freeze my flywheel, heat the ring and drop it on. If so is this balanced enough, where do I get the ring, do I need to balnce the ring first (not sure about this because the old ring was installed on the flywheel on the engine and all balanced as an assy)
ANY AND ALL REAL SUGGESTIONS WITH SOME TECH TO BACK IT UP IS REQUIRED and apprecieted.
I do not wish to jeperdize this fine piece of AMERICAN BIG BLOCK HORESPOWER.
THANKS MUCH CMC
[email protected]
513-227-6276 cell if you wish to cell
THANKS MUCH CMC
[email protected]
Charter Member #232
There was some info about this in Big Block Performance book. I can not remember what it said. If you can find Bruce then I would think that he has the info you need. Maybe some one has his number I hear he is swamped these days. I can not think that the ring gear could make a difference in the balance but DO NOT have that help you make your decision that is a total guess.
Jon
Jon
In the old days heat shrinking the ring gear into place was what was done. That is, you heat the ring gear, not freeze it - no particular orientation.
My opinion is that the ring gear itself is such a small percentage of the total wieght of the flywheel, that any out of balance of the ring gear would not effect engine balance. I'm certain it will be more balanced than the old ring gear with teeth missing.
I don't have specific knowledge of your application, but I always thought flywheel balancing was the same for v-8s of the same make and different for 6s. I once installed (accidentally) a v-8 flywheel on a straight 6. It was in a truck and when I fired it up it walked across my driveway on jack stands. Hair raising indeed!!
I think you are fine with any gm v-8 flywheel, but I'm sure we will find out if I am not.
BT
BT
Offshoreonly Advertiser
Ring gear, no problem. Cost is about $40, use a hammer and brass drift to drive the old one off. Heat the new one with a propane torch, drive it on with a brass hammer or drift. We have never had a problem with the balance. We have them in stock, or you can get it at an auto parts store. Pioneer makes them.
You can call me if you want at 954 321 0606
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
You can even heat it up in the wife's oven. I've been in a pinch and had to rob one off a flywheel sitting around. I believe it's a 168 tooth ring gear. Believe me, it's a 5 minute job.
Don't laugh, but I never thought of an oven! Of coure I don't have one at the shop hense the torch, but that is a great idea. Much less chance of overheating.
Marc
www.go-fast.com
www.bammarine.com
Marc
www.go-fast.com
www.bammarine.com
I've changed several. The ring gear should not affect balance.
Chevy made 2 diameter flywheels- 12.5? and 14 inch. They had 153 or 168 tooth ring gears. My Mercs have the large flywheels and I would bet that there was never a need for the small ones on boats. Less work for the starter, too. Ring gear can be bought at an auto parts store (NAPA).
- oh yeah, the Mercruiser website has parts breakdown for Bulldog motors with indication on motor number where transition from external to internal balance occured. Crankshaft, flywheel and harmonic balancer are different.
1) wear safety glasses
2) Bell housing mounted starter (#3SSM in my case) requires gear to be installed from the rear of the flywheel (drive plate end) and flywheel has a shoulder machined on it. Make sure to replace gear on the correct shoulder!
3) Tell wife you are cooking dinner. Place new gear in oven and heat to about 450.
4) Heat the old ring gear on the flywheel with a torch. Rotate to heat evenly. Use a brass drift (or bolt) to drive gear off- working around the gear evenly as possible. No need to chill flywheel.
5) With correct side of flywheel facing up, remove ring gear from oven and drop into position on flywheel. In my case there was about 1/16 inch of slop, which disappeared after about 10 seconds. No hammer needed.
6) Explain to your that you saved $1000000 dollars by doing a repair yourself and take her out for dinner.
