piston inspection >
piston inspection
piston inspection
Old 06-30-2008, 09:03 PM
ak
Default piston inspection
if you could look threw your park pulg hole in a big block,what should the top of the piston look like?this motor has 4.5 hours on it and runs great i guess.
ak is offline
Old 06-30-2008, 09:17 PM
21 and 42 footers
t500hps's Avatar
I was concerned about one of my motors last year and bought a bore scope so I could se the top of the pistons through the plug holes....look like when they went in just some black/burnt residue on the tops.
t500hps is offline
Old 06-30-2008, 09:21 PM
4.5 hrs should look damn near new. Very little discoloration if all is well.
Darrell.
DMOORE is offline
Old 06-30-2008, 09:28 PM
ak
the pistons had some black burnt residue on them also but a little wet or shiny looking,while some of them still look new around the edge but black residue in the middle?plugs are tan then start to get a little tan/black going toward the rear of the engine
ak is offline
Old 06-30-2008, 09:37 PM
Registered User
It has alot to do with the fuel system. If it has a Holley and it gets idled alot, you can expect the domes to be gunked up a bit. Holley's aren't the best idling thing out there.
Chris Sunkin is offline
Old 07-01-2008, 07:33 AM
It runs great you guess. Is there a concern with the engine? Like Chris said if it idles alot it will be loaded up. All depeneds on how your driving it. It will have some carbon on it either way.
Budz Motorsports is offline
Shawn D
2
04-14-2008 10:40 AM
gerritm
TOPPS
1
03-14-2008 12:35 PM
Whitey
2
09-26-2003 11:18 AM
Quick Reply: piston inspection
