Racing Oil Filters >
Racing Oil Filters
Racing Oil Filters
Old 01-09-2012, 06:46 AM
  #51
PatriYacht's Avatar
Originally Posted by picklenjim
Been running the K&N Performance Gold HP 6002 which is also a 2 qt. filter the last couple years with no problems. I also run a high volume pump and have the block by pass plugged. 100% of the oil goes through the filter. They filter down to 10 microns and have a max burst pressure of 550psi.
http://www.summitracing.com/parts/KNN-HP-6002/
The Nappa Gold 1794/Wix 51794 filters down to 21 micron and have a max burst pressure of 270psi.
http://www.wixfilters.com/filterlook...asp?Part=51794
That's a good price for that filter also. Thanks for the info.
PatriYacht is offline
Old 01-09-2012, 09:06 AM
  #52
does the 496 use a different filter number?..i am having problems finding listings for that engine?
pqjack is offline
Old 01-09-2012, 10:17 AM
  #53
Originally Posted by ROTAX454
Does Amsoil (Donaldson?) have a direct HP-6 Fram replacement filter? Used Amsoil filters on my truck. Great filter.
The Amsoil / Donaldson is an EA076. I've been running them for a couple of years, I also attach a high strength magnet to the bottom. My oil pressure stays constant before and after changes. My oil is so clean that I can hardly see it on the dipstick. You get the best of both worlds, high flow and superior filtration.
ThisIsLivin is offline
Old 05-21-2012, 01:00 PM
  #54
Try the Wix 51794R it is the High performance RACING version rated at 28 gallons per minute.
High performance version of 51794.
Wannabe
wannabe is offline
Old 05-22-2012, 08:14 AM
  #55
Just remember that the "R" on racing filters stands for Reduced Filtration.
Brandon
2
10-22-2007 10:15 PM
kennyo
13
07-15-2007 10:03 AM
stevesxm
15
04-14-2006 12:23 AM
Cord
4
08-04-2002 09:27 PM
innthered
13
06-27-2002 08:59 AM
Quick Reply: Racing Oil Filters
