Mermaid A/C Help
I have the Mermaid 6500 BTU model w/ reverse cycling. The unit seems like it is just blowing hot air. The compressor is running, pump is running, the sea strainer is clean and flowing water properly. The pickup vent is 4"x6" which should be adequate. Not sure what else to check. Could a switch or Valve be stuck? Thermostat bad? Any help would be appreciated.
if the compressor is running that switch is not the issue, I am a mermaid dealer, how old is the unit ? you sure the compressor is running and not just the fan ? had it been working ? feel free to call me Rob 540-786-8111
Rob,
The unit is about a year old. The unit was working when I purchased the boat this spring. How late is to late to call? I may stop by the shop tomorrow as I work in Fredericksburg.
dreamer
09-15-2004 02:06 PM
