World Merlin ( Teague 509 block)
Good morning group
Once again I need som help Last week I had a ring gear and new starterinstalled and it lasted only three days are there any issues with this applaction any one experianced this.
Rich
Rich
when you turn the engine over how does the starter sound ? any grinding weird noise ? did you replace the starter when you did the ring gear...you should have if you didn't. if it sounds weird or grinds, you have to shim the starter, not uncommon on gm's, also you need to make sure you are running the correct starter for you flywheel, gm did make a couple different ones...did you change anything just before any of this started ? Rob
