spark plug advice?
I have a 632 with dart 360 heads, dominator carb with 88"s in the front and a 6.5 pv and 95's in the rear.... i currently have a set of ngk -8 plugs in it but i am afraid that they are too cold. I used to run autolite ar3932 but they are hard to find around here. it has been so humid the the engine is fouling plugs and i think with a couple of jet changed and a hotter plug i should be fine. anybody have any reccomendations? does anyone elese run power valves or do you guys block them off?
You should be running NGK BR6FS or an AC R43T. You could run the extended tip version AC R43TS as well.
