A better Merc mechanical fuel pump (seawater pump mounted)?
OSO Moderator
Like alot of motors my 575SCi's have the lousy mechanical fuel pump mounted on the seawater pump. Like 99% of them, mine are leaking fuel into the oil reservoir and tearing out the seals on the sea water pump.
That said: the 525's also have the same fuel pump design. However if you look at Merc parts, the NEWER 525's (#OM956327 and up) have a new part # for the fuel pump (#889275T) but the same parts #'s for sea water pump.
Did Merc get smart and upgrade that POS fuel pump???
BTW: The part # for the old fuel pump is 842429a01
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
OSO Moderator
Bueller? . . . Bueller?
Lots have complained about these pumps leaking. Is it possible Merc has a better design and no-one knows about it???
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
OSO Moderator
Different? In what way?
Are you still getting fuel in the oil?
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
The hose barb for the vent line on my old ones came stright off the pump and on the new ones it turns up on a 45. I change the oil in mine every time I do the engines and before every poker run. The oil still smells gassy when I change it but it doesnt build up above the drain hole.
OSO Moderator
Bill take a look at these and see if they will work .(www.racepumps.com/index.html)
CV products does www.cvproducts.com part # CV2630
I may go that route and be done w/ the Merc Crap
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
I have 'em in my boat with no problems.
They're completely rebuildable.
I haven't changed gear oil yet so that will tell the tale if they leak like the stockers.
A shop nearby does a lot of stock car engines and I see CV pumps on them.
D
D
I don't think they will.
