KPM 112 / Mercruiser replacement pump body's
Anyone using the KPM112 replacement pumps secondary port to feed an intercooler?
I have a pair from a year ago that worked perfectly on my HP500EFI and was thinking about putting them on my 700sci's and running a separate line from the secondary port to the intercooler. What is the current concensus on these pump bodies and is anyone doing this sucessfully?
If you are, how much pressure drop to the engines did you notice?
Hi, if you would like to pm me with your email address, I can send you the info you require. There are a number of ways to have a second feed, either as a twin chambered pump or a second feed from a single chamber pump. Regards Pete,
[email protected]
[email protected]
