Battery question
Your systems legs should come right off the battery switch and have fusible links in them. One goes to the tabs/drives supply, one for dash/engine circuits and one for cabin circuits. Obviously this is for a basic performance boat. If you have electric fuel pumps that draw big current, another circuit is waranted. Big stereo? Another one. BIG stereo- separate battery.
Make sure your bilge pump circuit comes off of the feed side (input) of your battery cutoffs.
Chris thanks for taking the time to respond.
I will tonight run a 8 gauge power supply wire to a bus bar behind the switch panel also and tap into it.
that should take care of it.I hope!!!
Ran the 8 gauge power wire to a bus bar behind the switch panel and connected the radio,trim tabs and trim switches to it,everything now seems to be working fine,gauges dont jump up when I turn on the nav lights or any other accesory,radio also works fine while I use the trim tabs,seems to be all good at this time.
the only issue I still have is the radio going out during engine cranking,I never really paid attention to it before,I think that would be normal operation,Iam I correct ?????
Registered User
Run a search on here about Optimas. My experience was bad, as has been many others. Keep in mind, I buy them by the pallet for our fleet and I've had stellar service life from them in our trucks. The boat is a different story.
I buy the basic battery & replace them every spring.
You are are right about Powerquest Wiring, I laughed at a few of the connections / wiring. I did the same thing, ran heavier wire and took care of a lot of problems. As far as batteries, I run 2-6 volt batteries and one big diesel start for cranking the engines. I just spend 4 nights on the Mississippi river on an island with the refrigerator running and the radio, and my 6 volts never went dead.
My 2000 F260SS Formula came new with 2 deep cycle batteries. Replaced one last spring & the second one this spring. I think 7 & 8 years on a battery is pretty darn good. I stuck with the same.
