Switchable muffler question
Jeff I agree. All 4 could not go at the same time. I hear a clicking sound over the stereo thru the speakers so when I throw the switch something is happening. Just not geting to the Solenoids.
I just wanted to post the fix for this to help any one else who has this issue. The Teague mufflers have a solenoid on each tip & then they are wired to another small automotive type of solenoid that looks just like the old ford starter solenoid in a car. When you throw the switch on the dash that triggers the automotive type of solenoid ( mine is mounted right on the transom inside the engine compartment & that is what controls all 4 tips on my boat). If that goes bad then all 4 tips don’t work & that was the problem. It is $25.00 for anew one from Teague & I am all fixed. So I am told that it is nearly impossible for more than 1 solenoid at the tips to go bad at the exact same time & if all don’t work all at once than this is the fix. Good luck & thanks for the help from you guys.
Dave
Dave
jeff32
24
02-21-2006 01:56 PM
