Best oil for endurance or gasoline dilution? >
Old 08-29-2008, 05:40 AM
well... yes. i suppose. and if you are running that sort of boost at that sort of over fuel rate to cause the issue then i guess running uncured concrete for oil might be helpful in some fashion, but it seems to me that with the exception of the most extreme cases and those would be where you are forced to dump the oil after every pass, that running 70 wt in any modern motor makes no sense at all. and if you are putting that much fuel in the oil then you are changing the pistons , rings and most other parts as often as you are changing the oil anyway.
the drag alone would cost 80 hp never mind the pumping losses . not to mention that the relief valve would be wide open until the oil got to 240 and when cold you would need a billit oil filter.
but as everyone knows. if a little is good, more is better , and too much is just enough.
stevesxm is offline
Old 08-29-2008, 06:24 AM
Originally Posted by Hydrocruiser
Hi boost blowers dilute a lot..20W-60 in warm temp regions is the way to go.
Well said and top fuel dragsters are even worse for fuel dilution.
Ken
minxguy is offline
IRONMAN
13
10-16-2007 08:19 PM
OSO News
Offshoreonly Industry News
0
09-10-2007 08:47 AM
FunHome
05-21-2002 11:57 AM
h2owarrior
3
04-22-2002 06:40 PM
Quick Reply: Best oil for endurance or gasoline dilution?
