Trim Pumps
I am not sure I would bother unless your boat is 10 years old. I have never actually seen dirty trim oil. Lets say it does 2 strokes per hour? Multiply that by your boat hours...pretty low wear item...atleast for fresh water.
The way I change mine is in 4 footers...the cap comes off automatically and you get to clean your bilge too
![Grinser010](/forums/images/smilies/grinser010.gif)
I used to change the oil in my tabs every 10 hours until I switched to synthetic. I now do it every 15 hours. I installed a cooler and that seems to help too. Or was that the drive?
![Party Smiley 004](/forums/images/smilies/party-smiley-004.gif)
Also if you want the tabs or drives to move faster, you can run a thinner oil. If one moves a little faster than the other, you can cheat by running thinner oil in the slow pump.
