nobody uses spark plugs >
Old 09-06-2008, 06:50 PM
Hydrocruiser's Avatar
Arrow
Originally Posted by jayhawk261
Accel are made by Denso with the "U" groove! NGK has "V-Power"! I typically use the NGK plugs myself. I used the BPR6ES on my stock 454 MAG MPI.
Grooved plugs tend to spread out the spark and that is considered by most to be good as it gets the fuel touched off more quickly and evenly.
So it looks like Denso/NGK/Accel are the big boys.
Hydrocruiser is offline
Old 09-06-2008, 06:53 PM
Arrow
I assume (correct me if I am wrong) that you can use Double Platinum or Iridium's as a direct match for the "traditional plug".
If that is correct and it's so difficult to get to plugs (especially 2 bigblocks shoe-horned in an 8' wide room) ..why not use the best and go longer..like twice as long..between changes?
Changing plugs is mostly labor at any Marina too.
Old 09-06-2008, 08:10 PM
jayhawk261's Avatar
As long as the heat range is correct and the thread size & reach are correct, any plug will do. All in all, one plug is just as good as another in the world most of us play in. I think when things like V notches and U grooves make a difference is when you're making thousands of horsepower from one engine. On a 500 hp engine, I would bet any champion/ngk/accel/autolite/you name it will do just as good a job as any other. I think the thing you get from the bigger name brands at our level is manufacturing consistency and less chance of getting a bad piece. That's my $.02 anyway!
jayhawk261 is offline
Old 09-07-2008, 11:52 AM
Arrow
Quality control matters as you noted.
Old 09-08-2008, 10:05 AM
Ken N's Avatar
I have a stock 1999 502 MPI which NGK plug is best for me?.
Ken N is offline
Old 09-08-2008, 11:31 AM
Arrow
http://www.sparkplugs.com/results_ap...=215673&mfid=1
The traditional :NGK BR6FS ($2.24ea)
or
NGK Iridium BR6FSIX ($ 7.83)
The Iridiums will last twice as long at least as a conventional plug as they are better than even double platinum plugs.
Old 09-08-2008, 12:59 PM
Rob
Strip Poker 388's Avatar
this is what Ive used AC r43ts on the Hustler blower motor,which is close to a NGK r5674-8 I used on the Scarab blower motor
Strip Poker 388 is offline
Old 09-10-2008, 06:11 PM
SB
Received 3,177 Likes on 1,433 Posts
Coool, a thread I can join rightfully. i don't use spark plugs either.
Okay that was a slight joke. LOL.
Asking a question like this without giving full details on engine build is like looking for a car for someone that all you know about them is they have 30k to spend. Very unlikely you'll pick the right one for them.
SB is offline
Old 09-10-2008, 11:49 PM
So...... what spark plugs should I put in my car ?
Kidnova is offline
Old 09-11-2008, 05:38 AM
cig1988's Avatar
Originally Posted by ak
Why is it when ever i post a question on here no one replys?i try to help who ever i can when i can,but no one helps me,i posted a question about what spark plugs people use and got no replys,i guess no one uses plugs but me.funny i posted the same thing on baja marine and got a dozen answers quick-AWESOME!
WHY? 29 replies later not a single word from you? Thats why.
cig1988 is offline
Quick Reply: nobody uses spark plugs
