Gen VI 454 Engine Build Questions >
Old 08-31-2008, 12:59 AM
G'day all,
Great site with amazing tech support!! Now I've come up with my own problem in hopes of some assistance...
I'm building up a Gen VI 454 for a Stinger 222 and I am stuck on a few issues that are of concern.
My first issue is the heads: I have the Vortech 7400 heads which have just been rebuilt with uprated valves etc but are they any good to start with? I have read elsewhere that they will only flow up to about 4700rpm? Is this correct?
Second issue is the venerable Cam selection point. I am currently looking at the Crane 741 to match with ~10.3:1 comp, Strip Dominator single plane intake and a Holley 850 Marine carb. Exhaust is a custom stainless (wet) high flow with built in risers / elbow so they have a relatively short runner / collector length.
Is that cam any good for my set-up?
Intake @Cam 359 @Valve 610
Exhaust @ Cam 372 @Valve 632
Rocker Arm Ratio 1.70
Or would this Lunati Option #60203 do better?
Intake @Cam 268 @Valve 542
Exhaust @ Cam 276 @Valve 554
I've also been looking at this:
Intake @Cam 293 @Valve 629
Exhaust @ Cam 303 @Valve 612
Rocker Arm Ratio 1.70 with 114 deg seperation.
Any help or straight advice would be greatly appreciated!
Ghostrider is offline
Old 08-31-2008, 10:08 AM
All depends on what you want out of your boat, or the type of use. All out speed, cruis'n with the family, tubing/skiing....etc.
Best person to contact would be site member rmbuilder aka Bob Madara, of Marine Kinetics at 585-654-8583. rmbuilder has designed cams for countless people on this site and can tell you what cam/head/intake combo would be right/best for your needs. An rmbuilder cam spec'd specifically for your needs/application won't cost much more than an off the shelf'r.
Kidnova is offline
Old 09-01-2008, 06:30 PM
that intake is not very good for boats, the rpm level is way to high and you will never get there with out destroying the drive quickly, need something like a performer rpm air gap, you need to keep the max rpm between 5500-6000...my thoughts Rob
ezstriper is offline
Old 09-02-2008, 06:15 AM
Okay thanks! I've re-arranged my lofty aspirations somewhat, I'm mainly used to building car engines and the motor for my Sanger flat bottom! My guidance so far says I should get myself a dual plane manifold, an ~850cfm carb and run the #741 / 731 Crane cam to do what I need.
I've found a Performer RPM Air Gap, so I'll grab that. The Crane cam seems like it should do the trick without issues and I've found a few available down-under. Now all I need to find is the right set of exhaust for the right price. I'm looking now toward GIL or IMCO, Lightning make a nice set but I'd need a second mortgage!
Anyone have set they would like to dispose of? I can help!!
Thanks again,
John.
Old 09-02-2008, 08:49 AM
I've got a new set of Lightnings I paid $2400 for. I'll take $1800. Black powdercoated, probably have less than 2 hrs. on them.
kennyo is offline
Old 09-05-2008, 04:55 AM
That's Brilliant!
Can you post some pics or just email them to me at [email protected]
I have no idea about postage, I've been told via ebay that it should be do-able for less than $200 but we shall see... How much do a pair of Lightnings weigh anyway?
Another random question, anyone know if there are any fitment issues with Vortec heads and inlet manifolds? Also what jets would be best in a BG Demon 850cfm carb with a Crane 741 cam? What psi should I get with around 10:1 comp?
The more I think about it, the less I know about big blocks!!!
Old 09-10-2008, 09:26 AM
Kennyo . Email or call me about those headers..
Chris
[email protected]
727-599-1941
Blueabyss is offline
RickR
22
02-07-2010 01:04 PM
ddabal
Do It Yourself, Boating on a Budget
5
07-08-2008 01:40 PM
jt19392
3
07-24-2007 08:16 AM
TufEnuf
07-01-2007 11:22 AM
k24u
5
05-15-2006 12:41 PM
Quick Reply: Gen VI 454 Engine Build Questions
