Want to supercharge my 454mag
Lakeside Restorations.com
![](https://www.offshoreonly.com/forums/images/icons/commercial_member_star.gif)
You can blow your motor up if you don't set it up right. It is really not that big of a deal though. Once you get it tuned it is turn key. I have lots of friends that have done them. Mine handles great around the docks.
I had to make a few calls to Jamie here on the 502 mag. All questions were answered quickly and then it was done.
I have some friends that have had great success with the Whipple as well.
I ran a 7,000 lb single engine boat for 3 seasons on a Bravo I. Take it wasy out of the hole and don't stuff the throttle. Long term the XR is the answer.
I would recommend buying from Jamie. With some dealers the support is not there. If you end up talking to Procharger, you will not be talking to someone that has set up as many as Jamie. It is better to have access to someone responsive and knowledgable on the phone.
Thanks Bill...
![Smilie](/forums/images/smilies/smile.gif)
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
Looks even better in the boat! Wish mine was haulin ass. Hopefully soon. I'll let all the yahoos get winterized and get Eddie back out there!
I think a good initial setup (ECU, timing, fuel pressure) is key. Mine was good from the start. I get no transom soot, nice color on the spark plugs, and a smooth idle. It behaves just like stock power....until you start laying down the throttle.
What about a ROOTS BLOWER.... can the same performance be achieved and is there a major $$$price difference? I've come across a few USED superchargers... would I be gambling by looking at a used system?
Don't even think about adding a supercharger with out adding an oil temp gauge. It may save your engine. Your oil system should be able to keep your temps down to 240 at full throttle on extended runs . Don't ever let it go over 280. Something is wrong if it runs that hot.
Roots blowers work, but they are not as efficent as a procharger or a screw style like a whipple. ALso used is VERY buyer beware. Some are a deal, others end up costing you way more than RETAIL before you are done. I suggest getting a new one for your specific application no matter which one you choose or where you buy it.. It is the safer way to go..
Jamie
![Wink](/forums/images/smilies/wink.gif)
I'm glad I am getting posts from people with REAL TIME supercharging experience. Many people have given me a sense of negativity on supercharging (mainly that I am going to blow the motor, longevity of the motor cut in half, blow the drive), and of course not one of them have a supercharger installed........I guess too scared from the horror stories.
You did mention engine life,don't plan on running a supercharged engine without expecting to cut the rebuild span by at least 1/2 if not to a 1/4 depending on how much boost and how often you are in the boost. A 454/502 mag will normally last 400-600 hrs between rebuilds,ran hard 100-150 hours is about it,ran conservatively (with the ecu tuned perfect) you could see 200-250. My 502 m-3sc procharged 502 was still tight at 100 hours,at 175 it was burning oil and leaking from just about every gasket from blowby, (7-9 psi boost)I rebuild my 540 every 100-125 hours now,12 psi boost at wot,Smitty
I started out with a 1989mag.First put Stellings on it,that was around 2-3,then Merlin heads,crower 1.8 rockers,msd,total mph was 6-8.Ran it for 4 years around 220hr
then tore down and rebuilt,all new stuff, valves,springs,push rods,oil pump etc.... stock mag short block,went with 8.71Littlefeild 8lbs,pfm innercooler,a fair blower cam,2 barrygrant gold claws,775cfm,ported the merlins,Gil oil pan,teague oil cooler,ati,stock bottom end,30 over,made 767hp,ran about 4 seasons,changed too big ofa cam,1050s,12lbs, 828hp at 7200. 28 Scarab,then broke drives then.
I had the Scarab 12 years,sold boat 2001 with 500+hr,no blower,buddy bought it then sold it with 750+The Motor is still running
I kept the blower motor,put the mag back
![Ernaehrung004](/forums/images/smilies/ernaehrung004.gif)
GREEK LIGHTNING
06-19-2004 02:36 PM
