O2 sensor in CMI Sport Tube exhaust
Strip poker, thanks for the pics. That looks like about where I will be putting my sensor. My tailpipes go into Corsa diverters so I don't have a whole lot of room. Did you use both sides, or just one (odd side) like Dustin recommends?
Bruce
Bruce
I use the innovate system (LC-1) with bosch wide band 02 sensors - definitely go with a wide band... on one bank each engine. I'm running dry to the tip CMI sport tubes with CMI tails. My 02 bungs are on the sides of the tails about 6" from the joint - but I don't have water touching them due to the dry pipes... make absolutely sure you're not letting water touch the 02 sensors or I've heard they will go quickly.
http://www.innovatemotorsports.com/products/lc1.php
Good luck!
Good luck!
the two tail pipes in the middle,easy to get to.tried to get them in a 12oclock position
metric bung I think 18mm???
Thanks,Get Real
The overflow cover and cap are from F&M (see link below), they really finish off the motor nicely. I'd like to find a polished cover to hide all the wiring on the ECU.
http://www.customcowlings.com
