The highest ZDDP Synthetic I can find
Registered User
ZDDP is a chemical compound- zinc dialkyl dithiosphosphate. it's not just a dash of zinc and a dash of phosphate in the oil, it's a synthesized molecule.
Any oil can have high levels of ZDDP by simply adding it- it's commercially available. Raise your levels to 50K/ppm with a couple ounces.
It's being removed from many automotive oils because it damages catalytic converters, thus raising pollution levels.
On substitute oils, diesel oil is not good to use in a marine engine- it needs to be brought to operating temperature- unlikely unless the engine has a thermostatically-controlled oiling system. It's also very full of detergents which reduce film strength. It's also designed for very large-journaled bearing surfaces in low-rpm engines. Racing oils lack detergents that keep contaminates in solution and they also have other chemical compromises made in the effort to maximize shear and film strength. Most notable is the lack of acid neutralizers. Racing oil is made for short term use. It's not made to be left inside an engine and it's not made to last long- like a sprinter running a marathon.
In the end, unless you have a flat-tappet cam or a roller cam with incredibly high spring pressures and insane ramp profiles, your levels of ZDDP probably don't matter that much. Everything else in the engine runs in pressure-oiled bearings.
So, does this mean that the Valvoline VR-1 Racing should not be used? Currently, I am using the 40w oil.
Seriously considering Mobil silver cap or Mobil 1 V-Twin if I can see enough advantages.
OSO Moderator
Thanks - makes sense.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
I think you will be impressed.
Masher touches my
Teague's recommending Kendal 50wt in his motors under warranty. I was under the impression that the Amsoil and the Mobil 1 were better oils. What can you tell me about the Kendal?
As long as the diesel oil meets an API SL, SG,SH,"S whatever," it meets a gasoline engine specification and will work.
Ken
I'm sure ALL Teague's motors are roller cammed. The ZDDP concern is mainly for us Dinosaurs that still run flat tappet cams. I have been running M-1 V Twin for 3 seasons so far and haven't had any oil related issues.
Thats news to me. I know someone that just talked to him personally, and said he would only run the AMSOIL Dominator 15w-50, which is what he has been personally using for the last year or so.
Masher touches my
It says it right in my warranty paperwork. No multivisc. oil and only Kendal 50wt is approved, along with oil changes every 25 hours in a Teague 900. I thought he was an Amsoil guy too.
