aeromotive fuel pump
Hello, All Is A A1000 fuelpump too big for a single 525HP 502 carb. I plan on running 1/2 supply and 1/2 return line , does anyone know where to get a good deal on the marine grade blue fuel line and what make. I need about 38 feet. Thanks Alec
Bob
im running 2 a1000's on 2 500efis, i am running number 12 from tank to[inlet strainer] pump, then #10 from pump to fuel filter then to fuelrail then number 6 from regulator to fuel filler neck for a return. works perfect
The Fuel Pump Will Work Ok . You Will Need To Run A Return Style Fuel Regulator With A Fuel Return Line Back To Tank. Do You Want C.g. Aproved Fuel Hose Or Performance Fuel Hose. We Have Parker Bleu C.g. Aproved Hose (big $$$) And We Also Have Other Marine Fuel Hose And Performance Fuel Hose.
Is the Parker hose approved for pressurized fuel, ie between the pump and carb?
teaguecustommarine
New Products and Member Discounts
17
10-05-2006 10:35 AM
