Lifter Valley Screen Kits?? >
Old 10-23-2008, 08:29 PM
  #51
Dick,
Both the LSM and Jesel lifters are pricey...about $2500-3000 set. The Jesel website www.jeselonline.com says the tie bar .905 lifters are 229-231 gm depending on the wheel. The Dogbone style are 96-98 gm. I have the installation/set-up tool for the Jesel dog bone style.
Compared to starting over, $3000 might be worth the risk. This all assumes these lifters would work in your block. It is my understanding that all/most of the Craftsmen Truck Series racers use the Jesel keyed lifters.
BenPerfected is offline
Old 10-23-2008, 08:43 PM
  #52
Originally Posted by bob
Daredevil, from what I know of the big chief head, the valves are angled at 14 deg., the intakes are equally spaced, the runners are more symetrical/equal length if you will rather than having a couple longer than the other two, the exhaust ports are what 2"+ higher than a stock config? These heads flow lots of air/fuel but like to be up over 6000 rpm or feed large displacement motors. Maybe someone that actually really knows this head will chime in.
They added mat. to the block ,,,,so the height(thickness) between bottom and top of the roller hole is 3000 thicker then standart. So what happens is the roller bottoms out without touching the cam and as the cam spins around it beats the $hit out of the rollers and itself.
Thats my understanding ,the way my enginbuilder told me ?!
And if you think about it ,that can well be the problem.
I dont think it has anything to do with the heads, the spring press. or the cam and lifters ! Its the actuall height of the roller itself !
DareDevil is offline
Old 10-23-2008, 08:47 PM
  #53
Originally Posted by Mr Gadgets
Ben,
LSM gets a pretty penny for their lifters.. they wouldnt tell me how long they would last. He said he as a boat running them, but would not guess as to how long they live. The way he said it was not very convincing.
I am attempting to sell this block, heads, intake combo and start over. I just dont want to pass on a problem to the next guy. Lunati had the idea of a long duration cam with .670" lift.. real easy ramps. I would think that would do it, with lighter springs, maybe. If someone wanted it, I would let it go. I think it would look very cool in a 55 chevy somewhere!
Befor you sell anything, PM me and i let you have the name and # from my engine guy.
I cant post it because he is very funny when it comes to that.
I can tell you though he has build ,racecar and raceboat motors (ofcorse a couple of plessure boat motors ) for over 35 years,!!!!
And they all won and lasted.
Old 10-23-2008, 09:30 PM
  #54
2112's Avatar
Crane has also acknowledged a defect in the manufacturing of their lifters (top of the line pro-comp) and bought back 3 sets I had beginning to fail in the body section of the tappet. They blamed it on heat treating but I think it was a design flaw.
2112 is offline
Old 10-24-2008, 08:08 PM
  #55
Sounds like you caught your lifter problem early. "It's heat treating", etc, etc....it seems clear that many HP parts companies like Crane, Crower, etc don't have ongoing quality control processes. Don't you wish that Toyota sold aftermarket BBC lifters? What do these marketing focused companies have invested in the area of inspection, measurement or quality control? How do you know?
Isky claims their Red Zone lifters have extensive SpinTron test time. Do they test each production run or batch?
It becomes real clear that when many engine builders find a part that works, they are reluctant to change or step out of the box.
I'm curious, how did you find out Crane was having a problem your specific lifter?
Whining in TX,
Ben
Old 10-24-2008, 08:30 PM
  #56
2112's Avatar
I got lucky. Found an issue with mismatched retainers and decided to inspect everything down to the cam, pulling the manifold, and had to pull like hell to get the lifters out of the bores.
The lifter bodies are .873" the bores are .875 and the shoulders of the lifter where the axles are were .875+. Crane had the shoulders back cut to save weight.
I went back to my old heavy Schnieder (crowers) lifters. They are not cut back under the axle.
I am going to really upgrade the pushrods next.
2112 is offline
Old 10-25-2008, 12:05 AM
  #57
Just a thought, but does anyone think that durability of cam and lifters could be strengthened by utilizing the cryo treatment that is being used on the XR gears? If you treated the cam and lifter wheels perhaps there would be a durability benefit...seems to be working great in the drives....
SneakyPete is offline
Old 10-25-2008, 05:37 AM
  #58
I hate the winter!!
Vinny P's Avatar
I cant say if that would help lifters last longer, but I am the living proof of that process making drives last longer.
Vinny P is offline
Old 10-25-2008, 11:44 AM
  #59
Charter Member #601
Mr Gadgets's Avatar
My guy (I have Vinny's gears done) does cams, not sure if they can do lifters with out disassembly. That would be a manufactures process, I would believe. But valve springs are a deffinite canidate and I have heard nothing but good for the process. I am sending my next set of springs in to have it done. I will talk to him about lifters this coming week and see what he says.
Ben, in the process of searching for oil pumps, I came across an interesting thread about Melling Oil pumps. Seems they changed some of thier pumps to cheaper ( Auto Zoo demanded they sell the pumps to them cheaper) quality and kept the same part number. These drag race and street guys were going crazy trying to find out if they had good pumps or bad.
So even if someone finds the perfect product, you dont know from week to week if the manufacture is working for the stock holder or the consumer.
Soon we will all be GREEN and we will be worried about windings in our electric motors and battery life, etc. And I know the China batteries are junk!! LOL!
Mr Gadgets is offline
Old 10-25-2008, 11:56 AM
  #60
articfriends's Avatar
It wouldn't hurt to cryo the lifters BUT there are racing teams out there that have tried everything to reduce friction and increase durability on lifters,I would try to consult someone in the know for specifics (coatings/surface finish/etc). I have been having outdrive gears,transmission gears,ring and pinions from rear ends etc done and they seem to live longer.
It sounds like their is wildly varying of quality control on these parts that are failing. Two identical motors,one has all the lifters fail and they were from a different batch,definately poor quality control. 2nd scenario,engine pukes itself at 12 hours, unusually long pushrods/deckheight combined with high spring pressures,who knows then without a proven combination that used the same parts and lived or spintron testing. 3rd scenario,80-120 plus hours lifters start to fail,sounds like they are a service item at that point with a defined life cycle,Smitty
articfriends is offline
Bryan Rose
1
06-14-2011 11:11 AM
Dock Holiday
Baja
23
09-28-2007 10:55 AM
Bryan Rose
Prop Talk
3
08-24-2006 09:21 AM
1BIGJIM
6
03-28-2005 09:33 AM
p4-33
15
02-02-2005 07:31 PM
Quick Reply: Lifter Valley Screen Kits??
