msd or crane box ??? >
Old 10-22-2008, 03:37 PM
Default msd or crane box ???
Hello,
I have a thunderbolt four distrubitor in great shape and tried several times to move the rotor 35 degrees several times it comes very close but I'm not sure if its 35 degrees or not. I talked with crane and of course they never heard of any problems . so I was thinking to change to a MSD box or just a msd all in one distrubitor. any suggestions. Thanks
alecsammy is offline
Old 10-22-2008, 03:51 PM
I would go with the MSD.
mrhorsepower1 is offline
Old 10-22-2008, 03:54 PM
MSD !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:er naehrung004:
DareDevil is offline
Old 10-22-2008, 05:09 PM
I will no longer run anything MSD makes if they gave me the crap...MSD(may soon die) their now using junk chinese componants, unless you want/need arev limiter a mallory unilite works great and is much easier to set the advance than the msd...my opinion...just pulled all the msd stuff out of my top sportsman car after 2 failures of the same parts just months apart...pick-up in the dist. Rob
ezstriper is offline
Old 10-22-2008, 05:51 PM
Consider the using a Merc advance box. Maybe the V-6...what are your engine spec's? A lot of times used Merc boxes are available on OSO for a lot less than a new MSD Marine ignition and they are pretty much bullet proof.
BenPerfected is offline
Old 10-23-2008, 06:30 AM
boatman22's Avatar
Crane boxes for almost 2 years with no problems...572 motors
boatman22 is offline
Old 10-23-2008, 07:07 AM
WildWarrior's Avatar
Crane
WildWarrior is offline
Old 10-23-2008, 08:11 AM
KAAMA's Avatar
I think "Articfriends" (aka Smitty) could tell you guys a thing or two about MSD's stuff that he had ome disappointing experiences with their stuff right out of the box like 2-3 times in a row!!!
My experience(FYI)---I have run the same Crane Hi-6M ignition boxes and PS92 coils for the last 7-8 years now. My first water test with my boat a water cooling hose came off and began to spray one of my Crane boxes with high pressure water----that same box is in my boat today still doing its job all these years later. I will say that I still have the MSD billet distributors and MSD crank trigger system. The crank trigger system is a very reliable way to go---it eliminates the rusty pick-up in the distributor.
Doesn't DUI make a nice, self contained distributor?---I don't think it has a multiple spark though.
KAAMA is offline
Old 10-23-2008, 02:15 PM
Nordicflame's Avatar
Ditto on the Crane stuff!!
Just why are giving up on your hole task?
Nordicflame is offline
Old 10-23-2008, 05:45 PM
the msd stuff is garbage.
stevesxm is offline
Quick Reply: msd or crane box ???
