Jesel belt drive installation
http://www.meziere.com/ps-1211-1179-wp400up.aspx
I believe that these are the smallest spacers they have. I used these spacers from CV Products. I only needed .200, so using double gaskets would make the .250 spacer even larger. So, I had the .250 CV spacer machined for O rings.
http://www.cvproducts.com/catalog/08...el_Cooling.pdf
I hate the winter!!
Rotax,
Thanks, but finding a pump or spacer is not the problem I have. The problem is finding an appropriate pulley, that would keep my belt alignment, when the water pump is spaced out from the block.
Dick,
I made a mistake in the e-mail I sent you. The difference between my pulley and Johns 575 SC pulley is 3/4". His 575's use the same circulating pump as my engine does, so his pulley clears the pumps snout. The 575 pulley is the same diameter as mine as well. Although the 575 pulley is 1 1/2" deeper than mine, I would only need to space the pump out 3/4", due to the fact that the 575 pulley is billet aluminum. The front of that pulley measures about 3/4" thick, as compared to mine, which is very thin steel. There are 2 issues if I were to use that pulley. 1- The damn 575 pulley is ridiculously priced from Merc.
2- My engine bay is tight from bow to stern. Between the thickness of the pulley and the spacer needed, I would be adding 1 1/2" to the front of the pump. As it was, before this , shoehorning the engine into the blige was tight. The engine just cleared between the transom plate and the bulkhead, due to the long steel coupler sticking out of the bellhousing. When lowering the engine in, once the coupler cleared the transom plate and went into the hole, I would gain forward clearance. Remember, I have a 259 Convincor, as compared to you 283. Anyway, if I were to space the pump out 1 1/2", it may not fit in there in 1 piece. Not that its a big deal, but I would have to keep the pump off the engine, drop it in the bilge, then mount the pump. If I have to, I will go that route. However, at this point, my preffered method would be to use a 1/2 " spacer, and locate a suitable pulley with a 1/2" offset. I plan on calling March Pulleys tomorrow.
Plan B... Get a set of 3/4" spacers, bite the bullet and getted robbed from Mercury ( once again ) for the 575 pulley. Unless I find a deal on a used pulley from the OSO brotherhood?
BTW... Hey John, thats your pulley on the right!!
Dick,
If you felt like experimenting, since your old pulley is of no use to you now. If you have a friend who works in a good fabrication shop, you could cut your old pulley in half on a lathe and make a 3/4" ring shaped spacer and weld it in to make your old pulley "deeper". Assuming the inside diameter of that pulley will allow it. The key would obviously be to keep it running true and not out. But a good machinist/fabricator should be able to do this. Never hurts to get Creative. If it doesn't work, nothing gained/nothing lost. The old pulley prob. doesn't hold much value in resale, so its not like you lost a big chunk of change that was supposed to offset the cost of your project by trying.
Nick
Nick
I hate the winter!!
I did a full mock up, got it figured out for the 575 pulley. I made up ( with washers ) 1/2" worth of spacers to space the pump out from the block. That along with 1/2" worth of spacers between the pump and the pulley got me perfect alignment. That way, the pump is not too much further out than it was, so the engine will ( hopefully ) clear the bulkhead when going in and out.
Now all I have to do is talk to March Performance tomorrow to see if they have something else that will do, otherwise, 575 pulley it is.
I hate the winter!!
I hate the winter!!
Nick
Nick
Charter Member #601
Vinny,
I bet you could have a machine shop build a new pulley with the proper offset. Not sure if it would be as much as the Merc. I could ask my guy what he would have to have to build one? I see there are no ribs on that pulley. Just doenst look that tough to build from scratch...??
New white belt looks pretty cool!! But how will you keep it clean.. ?? I know you, you'll find a way!
Dick
Dick
Vinny, don't take this the wrong way...I would just put a good chain back on, whatever happened before(hopefully was a fluke bad gear) and it will be cured, but if not the belt drive will fail as well, the smal amount of h/p the belt drive will give you probably not worth the aggrivation of thie pully deal....just my .02.....good luck, Rob
