anyone ever heard of a MHP-301 cam??
Looking for more information on this cam and cant come up with anything....
All I know is it is a hyd roller cam, that is the part # and it is in a Gen VI 502....
any info is much appreciated, thanks!
yes i have the same thing ground on the end of my cam that came out of a 500hp. mercruiser grinds that on it. it is a crane
Part Number: CRN-169621
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 3,000-6,500
Intake Duration at 050 inch Lift: 230
Exhaust Duration at 050 inch Lift: 236
Duration at 050 inch Lift: 230 int./236 exh.
Advertised Intake Duration: 292
Advertised Exhaust Duration: 298
Advertised Duration: 292 int./298 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.598 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.610 in.
Valve Lift with Factory Rocker Arm Ratio: 0.598 int./0.610 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Grind Number: HR-292-2S-14 IG
mine had mhp-301 ground on the end of it
So it is a crane CRN-169621. thank you so much fixxxer....
So what can someone tell me about this cam? Is it pretty mild, somewhat aggressive? I had stock 525sc's and now am going to 502's with these crane cams in there..... just wondering how its idle is going to compare to my stock 525sc's.... thanks!
A 731 is .587/.610 226/236 on a 112 lob sep. I ran a 731 in my 525SC. I gained about 100rpms just with the cam change over the stock 525SC cam.
The 741 is .610/.632 236/244 112 lob sep.
Not a huge difference in them. If thats all you are thinking about doing, then I would just leave the stock one.
Its the same as 525EFI cam except the 525EFI cam is ground on 114 lob sep.
