Water thru hull location
You guys with Shadows, Chris Cats, and other cats with similar bottoms. Where are your engine water thru-hulls located?
Mine are thru the sponson pads (flanges mounted externally), about 5" forward of the transom, about 3/4" long, and directly in-line with the drives. I tried shortening them about 1/8" and that caused a loss of water pressure. Doesn't seem like a great location (as far as "drag" and water to the prop is concerned).
I've had chris cats set up with transom mounted and thru hulls. The thru hulls were only about 1 ft from the transom. Cut at an angle. Front was flush with bottom, back was 3/8" long. Both setups were as close to the tunnel as possible.
Gary
Gary
From some off-board discussions, it seems that the externally mounted flange might be causing turbulence, which makes it necessary to have a longer tube. I'll try a new intake with an internal flange. Thanks to all.
