Livorsi tachs acting strange - need help please
#31
By unhooking the alternators you lower the system volts by 2-3 volts and that alone can make a big difference because of the less amp draw on each circuit.
Hook it back up and check for A/C voltage out the back of the alt if it is more than .5 volt replace it.
Also did you put in new pick up coils in the dist, I have seen this cause a few tach issues before.
I will be down to the lake this weekend delivering the Fountain if you don't have it fixed yet and let me know maybe I can take a quick look.
I tried the wiggle test withthe cannon plug, it seems all good. But from the responses, I need to check the 5 and 7 plug wires in the loom, Alternators have not been changed probably in the last 7 years at least. I will check with Mike, the previous owner. I guess its possible they are bad even though they are charging the system? I also notice the volt meter on one of the motors kinda flutters a little and doesnt hold true like the other, but it has always done that.
Mark
#32
Thanks John, I appreciate that.... i will be back down Friday night and doing more testing on it with my buddy Saturday morning.... I am in the same cove as the fountain you are delivering... Condos right across the cove, Cigarette is at the the end of the inside dock... Third from last slip... the very end slip is a 36' and always empty, feel free to pull in there. I will probably be there, would like to meetyou and say hello if nothing else!
Mark
Mark
#34
Well, we did more testing this only to leave me even more confused. We found that disconnecting my alternators completely from the system made my tachs work just fine. So we swapped them out with the alternators from my buddies Fountain (same exact alternator/part #) and they still fluttered and fell back towards zero at 3800 RPM!! We also ran a known good tach directly to the coil and it worked fine.
Then we narrowed in on the harness to the alt's and the wiring to the tachs in the dash... ran known good grounds, signal, and power directly to the tachs with no improvement.
I spoke to Livorsi and they suggested I try a couple new tachs, ones with metal cases... mine are plastic. They seem to think it is interference/ radio frequency interference stuff that maybe the better cases might prevent. I think its a reach but bought a couple to try out. They should be here tomorrow. They are working with me so I cant complain. Said they would take them back without the resotckinig fee if they still dont work. The bottom line is the tachs were fine before the engine rebuilds, and the only thing different is the blocks (went from 454's to 502's)... I cant understand what could be different now that someohow some freak signal is being sent out to interfere with the tachs??? The alternators have me very curious.... but the wires going to them are all good.
Any other suggestions? Much appreicated fellas.
#35
SORE MEMBER
1 Post
Could try this............
http://www.lonestaraviation.com/prod...nator%20Filter
http://www.ngk.com/sparkplug411.asp?...esistor&mfid=1
#37
[IMO] You need to seperate the engine from the helm wires, If you can find a new cannon 10 pin wire harness plug from a dealer that might have a good old one laying around in the back of the shop area somplace, You could plug it in and and make up a small seperet dash on a borad of some kind and install a IGN key switch and a tack and what ever eles gauge you want to hook up to it and wire it up and go run the boat and see if it still does it. This way you will know if you are trying to fix the engine, or the wires to the helm or the helm gauges them self. It just makes it easer to find what you need to look at to start fixing. I do the same thing some times when I am trying to find a fuel problem, Seperate the boat from the engine, It so much easyr, Hope this helps if you want to do it good luck.
#38
That is a good idea. also is there any chance that you went from a resister type spark plug to a non resister? I am sure that you are not running the same plugs if you went from NA to blown
#39
#40
I did check the wire looms and ensured that 5 and 7 were not running right next to each other. I am also curious about the spark plugs myself. I know the builder put new plugs in but I am not sure what type they are, I will check tomorrow when I am down and into it again. The motors were already blown before so uit wasnt a conversion from NA to blown, but that still doesnt mean non resistor type plugs are in there.
I haven't gone as far intot eh wiring as boat teck suggested but it looks like that needs to be the next logical troubleshooting step, thank you for the feedback.
Any more suggestions? I really appreciate it guys.
