need help with strange 7.4MPI problem
Get used to it, it is not going away. As emission laws get tighter, pretty much everything will be forced to go to it to comply. Plus, the greatly improved performance and fuel economy makes it a slam dunk. Regardless of any other issues, nothing would EVER make we want to go back to a carburetor and distributor on anything!
Tom
Tom
Charter Member #1171
I have seen something as simple as a temp sensor doing what you describe,,,,, only dif being is is held a high idle on top of your simptoms,,,,not chocked it which leads me to belive the problem is after the controled circuit,,,,, also,,,,,, is there a ground cable between the two motors?
I want to live in a world where a chicken can cross the road and not have its motives questioned.
Another thought,,,,, do you have seperate tanks, or does both motors draw off of one tank?
It acts like something is suddenly telling the EFI to dump in many times more fuel than is necessary or normal. If the engine happens to be at idle at the time it happens, the idle speed doesn't change much it just starts running very rough. The odd thing is that the problem goes away and stays away if I keep the engine at about 4K or above.
Go Big or Go Home
Check all your grounds including those at the bell housing. also if you have not changed your cap and rotor yet change it. these engines are very sensitive to cap and rotor wear or corrsion.
Just a thought, try checking you timing under load, with the scan tool and a timing light, if the timing isn't correct replace the distributor the whole thing. Mark @ Precision Marine mentioned this to me about 2 weeks ago I was doing some troubleshooting on a 575sci
once a good tuneup is verified,,,,, I would also change the fuel water seperators.
next Id lrun the boat with a scan tool hooked up,,,,, save you alot of time and potentially money of guessing and throwing parts at it.
There is always the old way of swapping parts between engines,,,,,, but thats kinda hackish IMO
