crane ignition box HI-6m wiring diagram
Installing a used HI-6m ignition box with its coil, it has many connectors and would like to use my harness that has two flat connectors,one for the original module and one for the original knock retard both mounted on the side of the thunderbolt dist. Also want to be able to use my knock sensor.Does anyone have a diagram for the hook-up to save me time and possibly burning up a component... Thanks Frank.
It WILL work with your distributer if you re-phase your rotor according to their directions....
The ONLY "knock sensor" it was designed to work with was the Anson Turbosystems unit which, from what I've found, is no longer availabe....
Doug
I have the Crane HI6M modules on my boat so PM me if you have questions. I had a nice diagram of the wiring but lost it in one of the hurricanes.
Here is a pic of my drill jig to advance the rotor.
Long time cult member.
